Page 6 of 10 FirstFirst ... 2345678910 LastLast
Results 51 to 60 of 95
Thread: Airfield 1/72 scale modelling
  1. #51
    Default Re: Airfield 1/72 scale modelling
    Looks great - I hope the inside is as good as the outside!!!!!
  2. #52
    Senior Member mitrovitchp's Avatar
    Aug 2008
    Surrey
    One day I will get these onto a diorama! but for the time being they will have to make do with white card......
    All vehicles 1/76 scale;
    Some Royal Navy Ground Equipment (1/72 scale);
    Some Tornado Ground Equipment (1/72 Scale);
  3. #53
    Sep 2009
    RAF Balmullo
    AWESOME !!!!!!!!
    WE thats the royal we had some of the self propelled jobs, but like everything else the squadron guys couldn't be trusted with them; I think they may have all gone to the Navy just after gulf war 1. The 48Kws are being recycled for Typoon . As for the rest of the Typhoon kit I havent seen any but 6 are due here in a few months I will get a shoot done.
    TED
  4. #54
    Jan 2010
    'Bomber County'
    As a readily available kit, i thought this Link may be of interest to those who thought about improving the basic kit ..http://www.arcforums.com/forums/air/...=200882&st=120.
  5. #55
    Sep 2009
    RAF Balmullo
    Been getting to grips with the 1/72 Belcher Tallboy/Grandslam trolley; It has been a real battle, the main frame was badly twisted so it spent an afternoon in a bowls of hot water clamped to a steel rule. several different plaastic extrusions are supplied to complete the framework, but of 2 types there isn't enough to complete the frame work, luckily my box of plastic came to the rescue. That said the model is coming on well and I believe is good value . Thanks to Ian ( Able ) I have a Tallboy to show on it. I think i am going to paint the tail natural aluminium various sites give interior grey green, sky, and others natural; I read on a site they were not painted - posted by a former armourer who stated he worked on them ???
    CURRENT GSE/MT colours
    Had quick word with the paint shop at Leuchars re current colours:
    MT /GSE on tactical units Matt IRR or non IRR Green BSC 285. e.g. Harrier force and RAF regt. TMW, TCW, TSW, Some 2MT Sqn.
    MT /GSE on non Tactical units gloss green BSC 241 e.g. Leuchars, Coningsby, Lossie, Brize, Waddington. some 2MT Sqn.
    That said there is GSE here in both finishes and airfield use only vehicles are being procured in Gloss Golden Yellow.
    I think I mentioned the whole RAF there LOL.
    TED
    Attached Images Attached Images
  6. #56
    Ted, Richard Drew recently asked me about the colour scheme used on WW2 bomb trollies. I could't give a definite reply because I think that there was a pre-war colour scheme which ran over into early war.
    Was it RAF Blue/Grey then or something else. Modellers to the rescue!
    EDIT:
    I'm a large flying scale scratch builder myself. Here's my instrument panel for a long term project, a 1/7 scale Curtiss SC-1
  7. #57
    Sep 2009
    RAF Balmullo
    Hi Peter, All the evidence I have found is that GSE [as we now call it] was until 1947-8 the same colour as MT. So pre war RAF Blue grey, then subsequently the various cam schemes as they came into being. photographic evidence shows bomb trollies in a single colour this would be the base colour of the then current Cam scheme. I now have evidence of Cam painting starting before war was actually declared. Bomb trollies would have a colour strip indicating the owner Sqn. station Commanders were required to allocate a colour to each Sqn to ID its equipment. Also the 2 digit Sqn code was often stencilled on trollies. Overseas this code was also applied to the doors of MT vehicles. By the time the AMO A618/41 (august 1941) was published stating all MT to be Cam, I doubt if much was actually still in RAF Blue Grey.
    I also have a preceding AMO, AMO N629/41 ( june 1941) which clarifies the Cam painting of impressed vehicles . As with actions called for in DCIs in later years, most new policy in AMOs would have been given earlier distribution by a Directing Letter or if urgent by telex/signal. Evidence from files at Kew is that the RAF used the same colours from 1939 as the Army, but there there are no AMOs between 1937 and Aug 1941 on the subject.
    Peter et Al does anyone know the difference between an A series AMO and an N series. I sent a question to Hendon about 8 weeks ago but no reply ??
    I have found a picture of a Grand Slam with one of the access ports in the tail open, on the area the port cover would obscure is a much brighter circle than the rest of the tail, so I have to conclude that the tail was painted, and that the bright circle is bare Ali which had been masked by the access cover during painting ??
    That Dash board is great how long term is this project ??
    TED
  8. #58
    Hmm.Thank for the comprehensive reply Ted; seems that paint schemes were a little more complicated than I thought. The next question is what were the actual CAM colours?
    I know the difference between AMOs 'A' and 'N' but, like you, it is locked in the memory cells and wont come to the fore! I shall endeavor to find out from my contacts.
    Re the Grand Slam tail unit access panels. Your surmise is correct. The TUs were spray finished with the panels closed hence the circumference of the aperture was masked and would show bare metal when opened.
    My Curtiss SC-1 project has main float, tip floats, wing centre section, tailplane, fin & rudder complete ready for finishing, just outer wing panels and the whole fuselage to go. I estimate another ten years should do it!
  9. #59
    Sep 2009
    RAF Balmullo
    Peter, have a look back at my message No 22. In addition- from Aug 1939 until the first AMO on the subject was issued from Kew documents I am very confident we just copied the Army and used Khaki Green No 3 as the base colour with either Nobels dark tarmac green, dark green No5 or Light green No4 as the disruptive colour.
    bomb trollies and the majority of other items of ground euipment would have just been in the relevant base colour, items were only repainted when absolutely necessary
    i.e. 1939 onward Khaki Green No 3
    from late 1942 Brown Special to SCC2
    then from early 1944 UK Olive Drab SCC No 14.
    There is a firm in UK called White Ensign Models they do all 3 colours; however the feeling is the SCC2 is not very accurate so I mix my own from a formula. Let me know if you want more detail
    TED
  10. #60
    Thanks for that Ted; I have relayed your message to Richard Drew who is assisting an artist who is painting a depiction of work in a WW2 airfield Bomb Store so need to get the details right! I shall also amend my personal notes.
