Results 1 to 7 of 7
Thread: HOUNSLOW HEATH - First London Airport Memorial
    Default HOUNSLOW HEATH - First London Airport Memorial
    During its brief time as "London Terminal Aerodrome", Hounslow Heath witnessed two significant aviation events.
    1. The world's first scheduled passenger air service - London-Paris 25.8.1919 using DH16 G-EACT flown by Major C. Patteson.
    2. The departure on 12.11.1919 of Vickers Vimy G-EAOU flown by Ross & Keith Smith on the first successful flight from Europe to Australia.
    By April 1920 Croydon had become the favoured air venue for London.
    The memorial as it was 20 years ago
    [img]
    and as it is now (March 200 situated on the Staines Road opposite the junction with Barrack Road.
    [/img]
    Administrator NJR's Avatar
    South Yorkshire
    Default
    I see the local hooligan element have been there!
    Default
    yes...and it's not just the paint work. If you compare the earlier photo with the one taken a couple of months ago you will see that not only are the plate and engraving style different but the wording has changed slightly too. I wonder if the first plate "disappeared" ....?!
    Senior Member airfields man's Avatar
    Default Re: Hounslow Heath
    I was here today, pulled into Barrack road took a good look around...couldn't see it anywhere It's possible that I may have somehow missed it as it's quite a busy road with nowhere to park. I'll take another look next week.
    Found it today. One from the front, one from the park behind with over-flying aircraft and a closer view.
    It's not looking too bad I suppose for it's age there's a brick loose near the base which I pushed back into place. The green waste bins within the second photograph I'm sure were hiding it last time when I failed to see it.....well that's my excuse anyway.
    May 2010
    Cornwall
    Quote Originally Posted by airfields man View Post
    I'm not familiar with the plaque but I'm from the area....my theory is that the currently visible stainless steel plaque is the original installed by Heston and Isleworth Borough Council pre-1964 which was overlaid (by the London Borough of Hounslow) with the dark grey unattributed version in the first post and then at some time later 'removed'... possibly by ruthless terrorists whose cause is the re-establishment of pre-1964 local councils [and even Middlesex itself as a County Council ]
