Page 26 of 28 FirstFirst ... 1622232425262728 LastLast
Results 251 to 260 of 278
Thread: Pillboxes
  1. #251
    Senior Member SimonGee's Avatar
    Apr 2011
    Norwich, Norfolk.
    Default Re: Pillboxes
    Wot a load of old bull - !
  2. #252
    Senior Member netcompsys's Avatar
    Feb 2012
    North Lincolnshire
    Quote Originally Posted by P Bellamy View Post
    Great photo !
    kevin
  3. #253
    Senior Member HF Dave's Avatar
    Sep 2011
    Essex
    Please could someone explain what this square opening to the left of the entrance in this rectangular shell-proof pillbox is? It's clearly not a loophole as it is too high up and it has a dog-leg in it (i.e. there is no clear line of sight through the opening; see 2nd photo). The pillbox itself is on the GHQ line near Ford End in Essex. I think there are several with the same feature. Is it for ventilation?
  4. #254
    You are correct, it is for ventilation
  5. #255
    Sep 2011
    Essex
    Quote Originally Posted by StuartBr View Post
    Thanks. Presumably a local design variation? There seem to be plenty of the same basic type without this opening.
  6. #256
    The dogleg vent was standard on the Vickers MG box
    See http://www.pillbox-study-group.org.u...n-emplacement/
    It's not clear from your photos exactly what type you have there, but based on the location, embrasure in the blast wall and the fact that it is rectangular, it could be an "Eastern Command Type", which is a variation on the VMG Box.
    http://www.pillbox-study-group.org.u...-command-type/
    The diagram there doesn't show the vent, but from experience there are significant local variations in implementation.
    Regards
    Stuart
  7. #257
    Senior Member Mike's Avatar
    King's Cliffe
    It is an Eastern Command Type.
  8. #258
    Apr 2011
    Norwich, Norfolk.
    These dog leg ventilation ducts can also be seen on some of the T.28s on the GHQ Line in Cambridgeshire.
  9. #259
    Sep 2011
    Essex
    Thanks all for the information.
  10. #260
    As has been stated, they were common to Medium Machine Gun post typically the Vickers gun fired from a mounting. Considering that these guns (water cooled) were capable of sustained firing, the amount of gas blow-back from the muzzle was a liability in enclosed spaces especially if there was a wind blowing against the embrasure.
    The ventilation duct would assist the escape of warm air at ceiling level and create some ventilation. The dog-leg was intended to defeat furtive grenade or small arms fire against the occupants.
