Not a problem Peter, I knew what you meant...
After looking at some of the other 1940-design ordnance storage structures the possible SAA store seems to have a similar covered "porch" over the actual doorway, which in this case has had a low wall built across one opening that would otherwise entail stepping out to an 6' drop.
Hope that makes some sort of sense,
PB
