Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: Elstree
  1. #21
    May 2010
    Bristol
    Default Re: Elstree airfield, 1930s
    Quote Originally Posted by PNK View Post
    I haven't got a map but these might help. They are from 1949 anf 1939 (Dates are approximate).
    Thanks so much! The big one certainly shows enough detail for me to work out roughly where we watched from. All good wishes.
  2. #22
    Default Re: Elstree
    Some of the hangars at Elstree
  3. #23
    Default Re: Elstree
    The hangars look to be in good shape thanks for posting these!
  4. #24
    Oct 2012
    Default Re: Elstree
    I work in the bottom hangar! Cabair have gone and a lot has changed but it is a busy airfield with Helicopter charter flights in and out most days!
    New Tower is under construction
  5. #25
    Default Re: Elstree
    Hi Chris, thanks for the update. Do you have any more information regarding the new tower? When was it started? Timescale? Do you have any photos of it?
    Thanks and welcome to AiX as well.
    Richard
  6. #26
    Senior Member netcompsys's Avatar
    Feb 2012
    North Lincolnshire
    Default A (brief) history of Elstree Aerodrome
    found - A (brief) history of Elstree Aerodrome
    History of Elstree Aerodrome.pdf
    kevin
  7. #27
    Jan 2012
    Default Re: A (brief) history of Elstree Aerodrome
    I grew up in Borehamwood, and was very used to the seemingly constant drone of the light aircraft as they turned above our house for approach to Elstree. Was facinated by the push-me-pull-me aircraft (prop at front and prop at back). I'm going back 40-ish years, but I'm sure somebody on here knows what they were.
    As boys we would trek across the fields to the airfield and stand at the fence at the Eastern end as they came over our heads to land. Being good boys we never trespassed. Just as well we didn't know there was a public right of way across the aerodrome, or you'd have never kept us off it. The things you find out later!
  8. #28
    Jul 2012
    Isle-Of-Thanet
    Hi All
    Just came upon this thread because of my dad's service record ! He Trained as Link training Instructor, at the Central Link Training School which was
    at Elstree, he then went on to Binbrook. He didn't say much but he did mention Wellingtons and test flying, that would answer the question about training.
    John
