Following on as I reached the image limit...
So last year on a trip home I went back and tried to document what was left.
This is the Central Storage block although I'm not 100% sure if it's the original building. Possibly it's been reclad at some point. Certainly its in the same place and fits the same dimensions.
A shot of the yard area between the hut and the road. Quite a lot of flat concrete was still embedded in the ground.
There is a huge pile of rubble and earth which I think contains what was dug up of the yard at some point. In amongst the pile you can make out some definite pieces of concrete construction.
On the other side of the road was the location of the Traffic Operations building which has long gone. The track is marked private and I didn't want to chance my luck so I took the following shot through the hedge. I believe the scrub that pokes out into the field contains what's left of the buildings foundations which you can just about make out on Google Earth.
So there you go, nothing terribly exciting but another WWII site documented.![]()
