Results 1 to 9 of 9
Thread: SASKATCHEWAN - Weyburn
    Default SASKATCHEWAN - Weyburn
    No. 41 SFST Weyburn No. 8 SFTS Weyburn, Saskatchewan
    No. 41 SFTS Weyburn, Saskatchewan opened in 01/05/42 closed on 01/22/44 aircraft on strength were Harvard, Anson.
    No. 8 SFTS Weyburn, Saskatchewan opened in 01/02/44 closed on 06/30/44 aircraft on strength Harvard, Anson.
    Interestingly, there is one Harvard still flying that served with #8 SFTS and is currently with the Canadian Harvard aircradt association in Ontario Canada.
    Default Re: No. 41 SFST Weyburn No. 8 SFTS Weyburn, Saskatchewan
    second set of pics
    Senior Member kebecker's Avatar
    Jun 2008
    Darkest Quebec
    Great Pics Peter, I really have to get out west some day
    Default SASKATCHEWAN - Weyburn / BCATP #8 SFTS
    Weyburn still has an amazing amount of buildings present. It was home to Harvards and Cessna Cranes. Several hangars remain as well as H barracks, gun butt and mt shed as well as some smaller buildings.
    Attached Images Attached Images
    Default Re: SASKATCHEWAN - Weyburn / BCATP #8 SFTS
    Second batch of pictures showing what appears to be a small out building and the gun butt.
    Default Re: #8SFTS Weyburn Manitoba
    Having just checked the Nav Canada Flight Suplement which lists all Canadian airfields the only Weyburn is in Saskatchewan. It has airport code CJE3 and is still active with runways 06/24 3000x75m and 12/30 4000x75m.
    There is no other Weyburn airfield listed not even in the list of disused / abandoned airfields so if there was a Weyburn airfield in Manitoba it has now disapeared to the point it is no longer visible from the air. This is the criteria for coming off the Nav Canada list of abandoned airfields.
    Dec 2008
    Preston
    I thought the runway length was bit too long so I did some research. The runway is 4000 feet long, not 4000 metres. Blimey NAV Canada have you learnt nothing since the Gimli glider!!!!!!!!!!!!
    Canberra my fault rather than Nav Canada. I'm so used to looking at UK / European info where runway dimensions are in meters I forgot to check the units in the Canada Flight Supplement - should have remembered from when I was out there. Oops
