Results 1 to 8 of 8
Thread: Wickambreux, Kent
    OTBC norwichpaul's Avatar
    Default Wickambreux, Kent
    Took a bimble around St Mary's Church Wickambreaux today and was somewhat dismayed to find this plaque. It is unamed, and a search within the churchyard and church revealed nothing. The plaque seemed to be abandoned. Anyone know any more?
    Attached Images Attached Images
    Teesside
    Default Re: Wickambreux, Kent
    Squadron Leader David John Hatfeild Maltby DSO DFC , killed 14-15 September 1943 , 617 Squadron , Lancaster JA981/KC-J . On Ops to Dortmund-Ems Kanal carrying a 12,000lb'er when recalled but crashed off Cromer coast killing all 8 crew members of which 7 had made the last attack on the Mohne Dam .
    His CWGC entry here ; http://www.cwgc.org/search/casualty_...sualty=2655553 . If a CWGC headstone was not obvious then perhaps a family grave ?
    Ah! David I am maybe a bit demented, there was a VR pilot CWGC headstone nearby but I dismissed it as the date was over a month out. I failed to photograph it.
    The CWGC website confirms that Maltby is buried at St Andrews, Wickambreux,
    Have just re-read your post, Paul, and note that you refer to the church as St Mary's. Are you sure of the name, as only St Andrew's is listed for Wickambreux?
    Am sure its St Marys unless I am completely lost my mind (which is possible)
    Teesside
    I think you've lost your mind Paul . Compare your church photograph with this one ;
    http://www.ukattraction.com/south-ea...khambreaux.htm
    Perhaps you partied too hard and too long celebrating the Royal Wedding or just as you say , you've lost your mind !
    Photos by Fred Pearce
