| LCO |
LCCO |
MMT |
Order “Carry out a vertical
target change on the LRT” |
Take station in EET |
Acquire LRT on present target |
AIRFRAME AZIMUTH selected |
ATTITUDE VERTICAL selected |
Control Point switch to LCT |
Report roll gimbal angle to LCCO |
Record reported roll gimbal angle. |
Target Change switch to TARGET CHANGE |
Target Selector switch to ALTERNATE TARGET |
Burst Selector switch to NOMINATED BURST |
Instruct MMT to place computer
switches to LOCK |
Computer Switches to LOCK |
Control Point switch to EET |
Instruct MMT to carry out
vertical target change on LRT |
Select ALTERNATIVE TARGET |
Reverse Progress Indicator to ALIGN 2 |
Azimuth Reference switch to AUXILLARY |
Pass on new mirror angle as required |
Set new mirror angle |
Pass on new roll gimbal angle as required |
Set new roll gimbal angle |
Hand-set pitch and yaw null gauges into green |
Hand-set roll gimbal to give null meter gauge in green,
having checked deflection both sides of null |
Azimuth Reference switch to THEODOLITE |
Check stab gyro null gauges all in green |
Advance Progress Indicator to ALIGN 3 |
Check roll null meters tends to null roll gimbal angle correct |
Confirm EN Potentiometers driving to normal values |
Advise LCCO “Target changed, take LCT Control” |
Control point switch to LCT |
Observe Control Point Light is to LCT |
Select AUTOMATIC STOP
(Non-operational countdowns only) |
Computer Switches to ADJUST |
Set Vg Potentiometers to new values, do not zero |
Wait until ADVANCE appears |
Advance Progress Indicator to COMPLETE |
Select AIRFRAME REFERENCE |
Report “Target change completed
Pad xx” to LCO |
Order MMT to return to countdown
station or evacuate as required |
Return to station or evacuate as ordered |
Await instructions before operating
target change switch |
