Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
Thread: Visual Approach Path Indicators (VASI / PAPI / AAI)
    Default Re: Visual Approach Path Indicators (VASI / PAPI / AAI)
    Here is a repeat of the post mentioned earlier
    Drem Mk.1 in 1941 had 230V, 250W Angle of Glide Indicators - one only on the left of each runway, showing red / green / amber on approach. It was optimised on 5 degrees.
    Later that year, with the advent of Drem Mk.2, a slow rotating shutter was added to make them flicker. They were renamed AAIs and a second was now added on the right of the runway. Later still the left unit was lowered by 0.5 degree, and the RH one was raised by the same amount.
    This resulted in green and red when slightly too low, green and green when correct, and amber and green when slightly too high. Clearly two reds or two ambers meant way out!
    Administrator AiXAdmin's Avatar
    Jul 2009
    Notts - UK
    That answers the question I nearly posed yesterday... OK for the aircraft of the day, but would be a couple of degrees too steep with the advent of jets. (Same for any associated airfield approach aids such as ILS/PAR I guess)
    Bit steeper than the 3 degrees for VASIs/PAPIs.
    Senior Member Dr_Bishop's Avatar
    Jan 2012
    Outside Oxford
    The majority of VASI and PAPI were set to 3 degrees.
    Places like Binbrook were set to 2.5 degrees.
    IIRC, London City Airport are set at 7 degrees!
    Dec 2010
    I have attached photos of a sighting device that I bought with some other RAF items. This has something to do with setting up landing lights or similar. Can anyone shed more light on the item and maybe say how it was used. I would like to know for when I am asked what it is and how it works. I do know an ex RAF chap who`s job it was, (amongst others), to check approach lights and he used something similar which he had to attach to a platform at the end of the runway. This was in the early 1950s.
    On 27 at Leuchars it was a 2.5 degree glidepath. O9 and 22 it was 3 degrees, and on 09 it was 3 degrees because of the road, 22 was because of D604 aka Barry Buddon.
    Jan 2012
    Outside Oxford
    Quote Originally Posted by canberra View Post
    Well done Canberra. You have just past your TT for 2012!
    Im surprised you have marked me down for not knowing what it was on 04!! But in all my time at Leuchars I never saw anyone land on 04, and I only saw four Tornados take off on it.
    Jan 2012
    Outside Oxford
    04....?
    I never saw anything take off or land on it in two years.
    Quote Originally Posted by RAFerk View Post
    It is for adjusting the High Intensity GEC LA/11 Approach Light which looks like Post #343, presumably to 3 degrees. These lamps are more commonly seen as elevated runway fittings. I guess the angle of the latter would be lower as might the beam width / height.
